Surface Gap Plugs in '98 25hp
jeff_smith_0423
I'm getting ready to do my winter layup on my '98 Johnson 25hp twin. In the past, I've bought new plugs every year, gapped them, and installed after the motor was fogged so everything was ready to go in the spring.
I notice that L78V surface gap plugs are listed as compatible in this engine. I've run these in the past with my Merc's and LOVED them. Does anyone have any experience with them in the JohnnyRude twins? If they perform well, I'd like to switch.
Daviet
Re: Surface Gap Plugs in '98 25hp
I normanally take them out and replace them with the electrode type. I don't think they produce a good idle. Are they recommened for your engine?
jeff_smith_0423
They're on the list:
*20,25,28,30,35 (2-cyl) 1977-THRU? QL77JC4 or QL82C or L78V .030
They're the only recommended plug on the commercial model (although I have no idea what the differences are on the commercial other than badging )
oldrudedude
I have run them in my '71 50hp rude for two years. The PO had raised electrode plugs in it but the partsman gave me the surface gap when I asked for new plugs. I initially thought the PO was running the wrong plug but subsequently found that both are recommended for my motor. Surface gap plugs are better for WOT running and seem to load up at lower speeds or idling. I'm concidering switching to the raised electrode plug because I putt-putt-putt around a lot more than I run WOT.
EN2
The QL77JC4 is the best plug to use in your motor for all around use. These plugs have a heat range suited for trolling. The surface gap plugs are suited for constant high speed running, cool plug.
tashasdaddy
agree with EN2, the surface gap tend to foul out at low speeds. OL77JC4 are a much better all round plug. gapped at .030.
oldrudedude, if you putt putt alot you can open you gag to .035 to .040. to cut down of fouling, that is a very old trick used by those who troll alot.
oldrudedude
__________________
Thanks TD, I will give that a try.
