Seaswirl89
- May 17, 2021
- 35
Hello All,
it’s a long story so bear with me please…
Two weeks ago, I bought a great condition 89 Seaswirl Spyder that came with the original metal craft trailer. The trailer needed a new master cylinder (old one was dry and full of rust) so I replaced it along with the brake assemblies, bearings, new grease, and bleed the brakes.
Before I took it for a test drive yesterday, I lifted each tire of the ground and made sure they freespun with the actuator all the way out and they did. When the actuator was pushed in using the 2x4 method(a decent amount of force is required to get the actuator to push in any amount), the brakes were applied well and I was unable to turn the tires by hand. Same thing when I spun the tire in reverse, except I was able to turn the wheel backward so backing up was possible.Took it for a test drive and everything seems to work well. Checked the drums and they were warm but never got to a point where I thought they’d were too hot. I was also able to back the trailer uphill without issues.
But when I tried to reinstall the beak away system, No matter how hard I pulled the breakaway lever, I can’t get it to push the push rod in deep enough to lock the emergency lever in place. In fact the lever barely moves when I pull it hard by hand. So I tighten the bolt that compresses the spring on the push rod and the emergency lever is closer but still unable to pull it into the lockout position. As it sits the head of the actuator now has a lot of forward and back slop from tightening up that spring on the push rod assembly(the attached picture is before I tighten down the nut on the push rod)
When free spinning the wheels, you’ll get 3-4 revolutions and hit slight brake friction, I reused the drum rotor so they may not be perfectly round
The actuator is a original titan model 60. Any idea whats keeping the lever from pushing the piston rod into the master cylinder?
