Re: Suzuki 115hp late 80s
I agree I think a 17 is probably on the low side and it should rev easier.
We need your wot rpm and gps speed to evaluate your setup.
Some things to check Be sure the throttle is opening all the way.Does it have "whale tail","Doel fin" on the motor.
Are you adjusting the trim up for best performance?
Is it running on all cylinders? You wouldn't be the first to not realize you were missing a cylinder, except for the performance, even those with only 2 cylinder motors.
Is the motor in excellent tune?
Have you done a compression check?
Yes it has a whale tail, and yes the trim is lifted up quite a bit to get it sitting nice and light in the water. I will take the boat on the water to give you a GPS speed on Saturday, and the WOT rpm is 4800rpm.
The engine seems to run fine, on all cylinders other than if its left at 6kts for a while where it will cough, but other than that it seems fine. Is there a 100% definite way of telling if its on all 4 cylinders? Ive raced 4cylinder bikes my whole life so should be fairly in tune but Im just using any suggestions at the moment.
Compression is 120 120 110 115.
I'll check the throttle is opening all the way. Would be a daft reason but would be a cheap fix!
Thanks for all the suggestions!
Martyn
