Suzuki 1984 dt115 carb problems
bamitx
My boat has been sitting for two years. We changed the impeller, fuel hoses, and oil hoses. Bled oil lines that seems to be working properly. The engine seems to start and run ok, but while running the engine I have fuel coming out of a hole on the top of the carbs. Does this mean the carbs need overhauled?? Any help or suggestions would be appreciated. Thanks, Brad.
:confused::mad::(:eek:
Yamajoe
Re: Suzuki 1984 dt115 carb problems
Your float valve needle is not closing properly to shut fuel entering the carb. Best to overhaul the carb and adjust float levels as well.
