It is a 1989 Suzuki DT40. Motor starts, idles and runs up to 3/4 speed great. When at full throttle, it seems to de-throttle, cut-out and surge after 15-20 seconds. When pumping the primer bulb, it picks up.
I have replaced everything from the gas tank to a carb rebuild, including new primer bulb and new fuel pump. I have cut what I think are the water flow sensor terminal and then I cleaned the screen and then cut the oil flow/sensor terminal in hopes that might be the problem. Nothing has changed.
Are there specific wires for sensors that I may be missing? Or does anyone have other ideas surrounding this issue?
Thanks in advance,
Win
Thanks in advance,
Win
