Suzuki 1989 DT55C - lower unit
mz1bh3
Rookie Move!<br /><br />Hi I have had some recent problems with my 55 hp 1989 Suzuki<br /><br />Preliminary problems were Water Warning light and buzzer have been ringing and I witnessed the first revolution limiting function (much bogging and 2/3 power)on the motor. Excellent feature, needless to say it is the result of a bigger problem - being that it is a water warning I proceeded to try and remove the impeller - Rookie move - To remove the clutch shaft is virtually impossible because the screws are very difficult to get at! As I removed the 8 bolts plus the rear bolt I saw that the impeller assembly was sitting on top of a shift rod guide. I loosened the bolts on the impeller thinking that I could possibly remove the shift rod from the bottom instead of the top. The assembly dropped but the clutch rod came up.. Eventually I struggled to remove the clutch shaft assembly (removing the 3 screws holding it down). It looks like I should be able to replace the impeller with a kit (one of the rubber corners was in fact broken off) however I believe I have pulled the clutch rod out of position which would me that I may have to re/re the transmission assembly to put the clutch rod back in place... I am getting a manual in the meantime....<br /><br />Can someone confirm that my suspicions are correct. Thanks in advance for the help. :confused:
bossee
Re: Suzuki 1989 DT55C - lower unit
Hi,<br /><br />If the gear rod came loose in lower unit You must tear down the whole lower unit to get the spring, ball and rod in place again.<br />I suggest a Suzuki marine mechanic for that job.<br /><br />
mz1bh3
Hi and thanks for the quick reply. I thought that might be my only option...<br /><br />great on-line service by the way - first time using it.
