Suzuki 25hp outboard 2015 high rpm at idle.
atohmaz
Hi
On my 2015 25 hp, SOMETIMES, it starts at high rpm. Also, SOMETIMES, after having it running (coming back from a trip), it remains on higher RPM at idle. I noticed one thing though: Before I start it, if I turn the handle (I have tiller) as if I am revving the engine a couple of times and then I start it, it then starts at normal RPM. Any idea what to look for?
Thanks in advance.
99yam40
need to look and see what is causing/keeping the throttle plates from closing back as they should if that is the problem
lakensea
That is a high tech EFI engine and it could be something in the engine control system. Since it's still under warranty, why not bring it into your selling sealer?
