Suzuki '87 150hp oil injection
wjob
Seriously considering eliminating oil injection. Pros and Cons?
What's procedure to disconnect the oil injection system?
thanks
JUSTINTIME
Re: Suzuki '87 150hp oil injection
why it is very good
if u do u need to premix perfect every time
wjob
JUSTINTIME said:
why it is very good
I've heard on the older engines better off disconnecting, safer to premix?
JUSTINTIME
u are thinking vro
the oil pumps are very good
if u are that paranoid just buy a new pump
wjob
I appreciate all your help. Come to think of it, I guess I should get an intermitent horn warning if I have a oil problem. Should the engine also slow down if there is an oil problem or just when there is a cooling problem?
Bill
JUSTINTIME
it will go in RPM reduction mode so u can get home or 30 mins of use
but u can reset that to get full rpm
deejaycee_2000
when there is a oil problem it will stop fire on half the cylinders and limit the rpm to 3000, if you wanto disconnect the oil pump you need to take the oil pump off and take out the shaft that make it work and put it back thn mix the fuel 50:1 ..... suzuki have one of the best oil injection systems so you shouldn't really have problems with it ......
