i have an 89 suzuki cabrea el85 engine that is having serious rpm/throttle issues. i can start it up out of the water and run it at full throttle no problem at all, but as soon as it gets in the water under a load, the rpm cuts back to no more than 3200 rpm, and it will not accelerate at all. also i notice that there appears to be alot of fuel leaking out of the prop area while in the water when attempting to throttle. unfortunately for me there arent any suzuki repair shops in my area so im kinda on my own here. i did have a friend that works on some other models tell me that its possibly a power pack. can anyone please help???
i wanted to add that i have had a compression test ran and everything looks great, very sound mechanically, also put new plugs in just incase and same result, no power under load will not go over 3200 rpm. thanks for any advice you can give me!!!
