suzuki df140 cuts out at 3000rpm
carter140
hi, my 03 df140 with 20hrs on it starts fine, idles fine but at 3000rpm surges,won't throttle up. i have replaced all filters,low speed fuel pump,and neutral switch. there are no warning flash codes showing. is there a sensor or control i could try to replace? i have a warranty but there are no suzuki dealers on MV island so any help would be greatly appreciated, thanks
lakensea
Re: suzuki df140 cuts out at 3000rpm
Engine mounted neutral switch is stuck. Shifting in and out of gear a few times generally frees it up. If not, remove starboard side cover and work switch plunger with needlenose pliers.
carter140
problem happens while in gear, i have already replaced and checked operation of neutral switch
clanton
Check the switch again, the switch tells the computer when engine is in gear.
carter140
i double checked the new switch i installed, same result. i might haul this boat off island to the nearest dealer and forget about fishing season! any suggestions? thanks
clanton
check the fuel rail pressure.
carter140
replaced high pressure fuel pump, problem solved. thanks for accurate info
