Suzuki DF140 fuel starvation
2tides
Engine starves at idle after 15 mins or so. I have two fuel tanks one close and the other about 11 feet away. Both feed a Racor fuel/water separator. The engine runs fine on the close tank, but starves after time when run from the far tank. Both tanks clean, new filter and body, fuel pick up clean. Planning on running a new line to tank to determine if line is blocked. Could this be a low pressure pump issue? Engine performs perfectly otherwise.
99yam40
Re: Suzuki DF140 fuel starvation
monitor the vacuum on the suction side of fuel pumps or filters to see if there is a restriction and find out where it is.
Could be sucking air also
