Re: Suzuki DF70 trouble light code
The code is telling you the cylinder temp sensor system is defective, like sensor, wires, connections, ecm. Up to you locate the problem and repair. You do this with a meter and manual. Some of these sensors were defective when new. Dealer service bulletins has the year and model of engines with defective sensors. 2 temp sensors on this engine, the 2 readings are compared by ecm, if out of specs will set code.
