I replaced the water pump in my motor and now I am having problems getting the adjustment right for the shift mech.
when I start the motor in N the prop doesn't spin. What is the magical way to adjust these correctly? When the shifter is in N the prop spins freely, when it is in forward I can spin it by hand but it clicks with some resistance and the same with reverse. I took it out after I thought the adjsutments were on but when I went forward I couldn't push the throttle all the way forward.
Also when I put the new pump in it said to use some sealant. I used clear silicone sealant were the lower end and the crank case meet and on the bolts like it said to. Will this work or do I need to pull it back apart and put the correct stuff in?
I've had this boat on the water for almost 12yrs and when I pulled it apart it didn't look like there was any type of sealant ever used. I probably used the wrong stuff and should take it back apart so some of it doesn't block the water outlet.
Does anyone have a manual in pdf format that I could look at? Thanks for any help.
