Suzuki DT 65 Oil Filter
Trackbolt
My 1987 Suzuki DT-65 had developed an oil leak. Turned out to be the oil filter was leaking at the seam. I have a new filter. and some line. I want to replace the line between the tank and filter and the filter and oil pump. I plan to replace the lines and filter but before I connect the line to the tank I am thinking it may be a good idea to use a small pressure oiler to inject some two stroke oil into the empty lines and filter before reconnecting the tank. I then think I would put some 50:1 in a tank and run the motor opening the bleed screw on the pump to purge any area.
Thanks
