Suzuki DT115 Voltage Regulator/ Rectifier
rrw
Hi,
My 1986 DT115 isn't charging. This model has a separate regulator and rectifier (32800-95D01 and 32800-94601). I've attached a pic of mine, they look to be aftermarket as they don't look like any of the OEs online. The Rectifier (95D01) tests bad, I can't find the procedure for testing the regulator. Does anyone know if I can replace both of these with a 1 piece unit? Otherwise I can find OE rectifiers for about $80, but can't find any regulators (32800-94601) and would like to replace them both, assuming they're aftermarket and likely low quality. Any insight is appreciated. Thank you! 20230701_080942.jpg20230701_081856.jpg
boscoe99
I presume that you have but two electrical leads coming from the stator coil. Is that correct?
