Outboard motor has a prop wobble and the prop shaft is bent although it still turns freely. There is I believe excessive play in the shaft when in gear and want to inspect/resolve. I have an original service manual for this motor and have removed the gear linkage, three nuts under unit and one above in front.
The lower unit has no movement what so ever, it's just like everything is still bolted together. Tried the shock it free with a rubber mallet, dont want to try more agressive measure without advice. Please help, motor runs fine, starts first time everytime, I have not actually taken this motor to water yet as it was an add-on to a trailer sailer I have recently bought. thanks
