Suzuki DT25 Won't start
hope761fish
HI, can anyone help set me in the right direction? Last month this motor (suzuki dt25 two stroke mid 80's model) started right up and ran fine, i mean great, I tried to start it today and it's not firing, No fire at the plugs, I cleaned them up and still no fire, can the coil go bad just like that, anyone have any troubleshooting idea's i can try, i can't afford to put it in the shop right now, I will appreciate any help anyone can give, thanks in advance
deejaycee_2000
Re: Suzuki DT25 Won't start
I would also think kill switch, lube it with some WD 40 .....
deejaycee_2000
If there is no spark at all of the plugs then I would check the stator, all the coils can't go bad at once and the CDi will not fail, their fail rate is 1 in a million ....
James R
The linking of the kill switch wires does the same as the kill switch when stopping the motor. Disconnect the swtch and try again.
