Suzuki DT30 need help please
Nitro6Two
I am new to boating. Just got a 16' Duroboat like new from a friend and he threw in a Suzuki 30hp motor. I don't know anything about boat motors but I am good mechanicaly. I was told the water pump impeller would need replacing and that sounds easy enough. the other problem is that who ever owned it previously must have dropped it, the tiller handle snapped off and missing. The kill switch wiring is intact. My friend thinks that the motor will not get spark to fire unless I bypass that kill switch wiring. Can you describe what I need to do?
Other things I can use help with: I beleive this motor to be a 2 cylinder 2 stroke, older, not sure how old though, is there any oil levels to check or oils to change before attempting to fire this motor?
Thank you so much for all of your help.
