suzuki dt30 steering set up
gamekeepa
I've bought a microplus 501 with a suzuki dt30 outboard.Ther boat has a steering wheel and a single cable.The cable isnt connected to either the engine or the wheel and i dont know how to do this.The back of the steering wheel is threaded whith i slit running down about 2 inches of it.Either side of the engine transom the cable runs through a pulley.Any advise would be great.Cant wait to get on the water.
Whoopbass
Re: suzuki dt30 steering set up
Here is a few pics of the steering linkage on my 1990's 30 HP Suzuki (3 cylinder).
James R
Sound like you have an old vintage type steering system. Doesn't work with the late model motors. You will need a complete replacement steering system and a drag link for your particular motor. Go to brownspoint.com, parts, and look up your motor for the drag link.
smartcaddie
I also think you have a vintage steering system. but can you provide more info or maybe some pics? that would help alot.. in a DT30 there are a couple of ways of installing a steering cable.
gamekeepa
Thanks for the replys.Will try to post some pics to give you a better idea of what cables and steering wheel i have.
marine4003
Whoop...those are pics of your throttle and shift..not steering, there should be a tube that runs in front of the engine..threaded on one side..thats where the steering cable threads into...more pic's..
