Re: Suzuki DT40 rough idle
Hi David<br />NGK B8HS set at 0.8-09 mm by the book. Use BR8HS if you need suppressors , I'm currently useing BR7HS's set to 1mm to overcome an oil fouling problem , the lower the number on ngk's the hotter the plug temp (opp of champ plugs).<br />As for rough running , I gotta say my lawnmower runs wayyy smoother , it misses, pops, vibrates. Stripped down the carbs soaked all the parts in carb cleaner and blew compressed air through all the carb holes and it made no difference at all to the rough idle. It did improve pickup and mpg. Gonna pump a can of decarb spray through iy next week. Manual recomends a decarb after every 50 hours of use. 95/92 psi cold 120/130 warm.
