i have a suzuki dt40 that i have just changed the impellor, pump housing, wear plate and gasket. when i connect the flush system there seems to be alot of water coming out of the tell tale hole however after running the engine at idle for approx 30 mins the water turns to a fine spray and the engine runs quite hot.<br /><br />is this normal?????
