I have an oil injected single carb DT40. I had the motor running last year before the water impellar broke and the over heat alatm came on. I wasnt on the Lake but at home when this happened so I shut it off immediataly. I changed the impeller over the spring and just got around to starting it and now I dont have spark.
I've checked the kill switch and it hasnt moved. I have oil in the oil container. I checked the fuse and it is good. Ive never had an ussue with it firing over before. What could I be overlooking?
