Suzuki DT65 water sensor problem
comi1
I have Suzuki 1985-1987 DT65 motor.
Problem description:
After turning a key in on position beeping sounds every 4sec and red light comes on. After starting motor beeping sounds every 4sec and red stays on. Water is running from a peehole. This is first time on the lake after winter. I don?t have a manual, is this beeping ok when key is in on position??
I have traced wires that go to water sensor and disconnected them and beeping and red light stops.
I have tried to check water sensor for connectivity, nothing. Is this is good way to test the water sensor??? Is any other way to test?? Is a something I am overlooking?
Don?t have a lot of experience with outboard motors.
Just want to make sure my troubleshooting is correct.
I have found new water sensor on brownspoint.com. Is any other website for Suzuki parts?
Thanks in advance
parrfive
Re: Suzuki DT65 water sensor problem
The sensor you?re talking about is a water flow sensor. It has a kind of flap that hangs down into the water jacket. It the flap is stuck or broken you will get an alarm. Pull the sensor out and inspect.
comi1
Thanks for the advice. Yes, this is the one that flaps, the nothing broken.
How to test this sensor??
