Suzuki DT75 ignition switch & non firing
New project. Has run b4 sitting up for years, fired off with ether then Started basic cleanup/prep for fresh fuel, etc. Noticed #3 plug dead. All 2 Coils r working. Got 3 new NGK OEM. Verified spark. Then, no spark. Early in, ignition switch wasnt making contact. I suspect old grease on contacts but eventually started working & spinning engine. Now no spark. I hav new switch on order. Suspect bad switch contact. Im on fam fishing trip deadline so need to make progress & verify running asap. How can i bypass the igniton switch (hotwire) to continue troubleshooting b4 the new switch arrives. Cant find anything online. Is there anything else simple i should check? Kill switch was working. Neutral switch was working. Doubt its the cdi or coils since has been firing when spinning while tinkering. Its Possible but hoping not likely? Seems 2 b simple issue like switch, i hope. Just odd 2 suddenly stop firing while tinkering. Hence, the switch theory. Many thanks for your time. Any articles on testing cdi & magneto, etc would b greatly appreciated.
99yam40
not sure about Suzuki's, but with Yamahas I would measure the input voltages to the CDI and output voltages of CDI to make sure what does and what does not meet specs in your service manual.
that should narrow down where to be looking
if you have good input but no outputs, I would think the kill switch or wiring is grounding stopping the voltage out of the CDI
Thanks. 10 wires, no ckue which to test, no manual yet. Cant read digital manuals online. Need a lil help on the procedure.
you cannot read the digital manual why not? the easy test procedure is in there. you will not find the proper test cord so get ready to probe some leads with your DVA and multimeter and seal holes back up with liquid electrical tape. god help you if the CDI box needs replaced!
