Suzuki DT85 won't idle down
n2diving2003
Just doing some backyard maint. and when I ran the motor up to 3500 rpm I could not get the idle back down using the throttle. Is this a cable problem or something sticking with the linkage? When I idled up using the linkage it did the same thing. Shutting the motor off resets it. Any ideas out there?? Thanks
JUSTINTIME
Re: Suzuki DT85 won't idle down
if u rev that motor up in neutral it is not good for it
