Suzuki has no power to anything.
rogertee
I have a 2010 90hp Suzuki four stroke. Last season I put it in storage and this season it won't crank over , no tilt. When I turn the key to on there is no noise, beep whatsoever and the trim and tilt doesn't work either. Battery is fully charged, fuses all good. What could be the problem, ECU, relays any ideas?
Thanks in advance..
99yam40
you need to test to see where you have 12 volts+ and where you do not.
Start at the battery and work your way to the motor
