Suzuki Oil Injection System
jass1961
Just purchased a '92 Suzuki DT30C,it is in overall very good condition.The oil injection pump has been disconnected and the oil tank removed.The previous owner pre-mixed oil/gas in tank.I haven't ran it on boat yet but runs fine in water tank,are there any problems with running it this way?Any help would be greatly appreciated.Also would anyone know proper oil/gas mix ratio?
stylesabu
Master Chief Petty Officer
Re: Suzuki Oil Injection System
there are many posts on this, the pump must be removed, as the oil from the injection system lubes it. the system works pretty well as long as you use clean oil, see if you can put it back to oem
jass1961
Thanks for info,doesn't the pump have a shaft coming from crank case?Don't understand how you can remove it.
stylesabu
ive never had one apart. just going off pictures in the manual
