this is for rodbolt thanks a bundle for your advice re my suzuki 100 on inspection I found the oil filter was clogged with resin and was causing a vaccuum that set off the warning and rev limiter I have since located an engine monitor and will be fitting this to assist in maintaining engine<br />once again thanks <br />el sid
