Re: Suzuki Sail 8hp fouled plugs
Do you have a sail prop on this engine. If not you are lugging the engine at too low an rpm which will contribute to plug fouling and overheating. If you have the correct prop then you need to check spark, compression, and mixture. An overrich fuel mixture or too much oil from the oil injection will also contribute to plug fouling. I'm betting on the prop.
