Have a 2003 suzuki 225 dt counter rotation that has a problem shifting into forward. It works some of the time and when it doesn't I shift it into reverse then back into forward and it works. This does not happen every time just once in a while. When looking at the shifter under the cover it seems to be going into gear just fine. Like I said this only happens once in a while. I changed the lower unit oil and no water or metal . When it's in gear it runs fine. The prop has not spun. Hope someone has a answer.
