suzuki thermostats
joeboston
Hi Forum . This is my day for questions. I bought a 2000 suzuki 150 2 Stroke a while back. I ve found as time goes on different issues. My question is what is the proper way for installing the thermostats. They can go either way that being ,spring into block or reversed any info would be appreciated Thanks:confused:
99yam40
Re: suzuki thermostats
all the thermostats I have seen have the sensing element in the block so that it can sense the temperature of the water there, but I have never looked at a stat from a Suzuki
joeboston
Thank You for a reply to my question. I m still unsure because I had another opinion on this so I m going to keep the question open as I m finding out the suzuki s are a little different then other motor brands:confused:
joeboston
You are the second person to agree with this .It does seem backwards doesn t it? a few years after I bought the boat I changed the thermostats and replaced them the way they originally were With the springs in. I guess they were replaced wrong before I bought the boat Thank You
larryhere
sometimes its helpful for me,,,,,,,, you can view the microfiche's for all suzuki motors on brownspointmarine.com in NJ. you can also compare part #'s for interchange and shows where things are!
