Suzuki Won't Start
derkkd
I have a 75 Hp Suzuki that I can't seem to start. I have gone thru the procedure of priming bulb, turning key adn holding choke for 8 seconds and then trying to start. No luck.<br /><br />Only way to get it to fire up is to spray fuel directly into carbs..Fires right away. Is my start up procedure wrong?
JB
Re: Suzuki Won't Start
Howdy, derkkd.<br /><br />Go to Engine FAQs and check it out.<br /><br />Your procedure may be wrong or you may have a carb problem.<br /><br />Good luck, and let us know what you find. :)
classic 24
you have to hold the key in while you are turning over the motor. If it doesn't stay running after you get it fired, you probably have dirty carbs.
rcgt78
Hi,<br /><br />Are all the choke plates closing?<br /><br />Check for leaks at carb -> intake, <br />carbs, fuel pump, etc.<br /><br />"Holding choke for 8 seconds"<br /><br />Does the engine have a primer instead of choke plates? <br /><br />Robbi
cddetelich
Had the same problem with a Suzuki 85. Spoke with a mechanic and he said some Suzukis choke butterflies didn't close enough under battery power and that I should try using manual choke. Problem solved! So then I adjusted solenoid that pulls choke closed to make sure *** was really pulling butterflies all the way closed and the problem ws fixed. Make sure battery is fully charged also-solenoid needs a good jolt of power-
Jay B
My old 115 was the same way- At least till it blew sky high 2 weeks ago. Try this- Turn the key on, then push in for choke before you turn the key to start. I found the solinoid would stay activated while starting but sometimes wouldn't come on if the starter was drawing juice. A good battery is a must. The ignition needs right near 12 volts to fire right, which it may not be getting with a weak battery with the starter engaged.<br /><br /><br />Jay
derkkd
Thanks for al that...Tried it all and still having problems. Not sure where to go from here!
