suzukie 250 will trim down not up. Not ptt relay. Advice please
patrick2664
Approx 2 months ago my port motor would not trim up, then it started working and has for 2 months. a few days ago I was changing oil and realized that it would not trim up. It will trim down. I can trim the stbd up and down with the port throttle trim button (its the master when I choose synchronous trim). I started reading diagrams and doing research. I starting tracing wires. There are a pair of wires (blue and red) that come off the ptt relay assembly. The blue is for up, the red, is down. I can actually raise the motor up by jumping the red to the blue wire (using the down button on the cowling control). Its as if the blue has no "power". I spoke to two mechanics who said it is most likely the relay. I changed the PTT relay assembly as suggested and have not fixed the problem. I'm lost at this point. Is the problem on the motor? Throttle control? Corroded wire? Need some advice.
dingbat
I’ve had the helm switch fail on two different setups.
Put a meter on the wires coming from the switch to see if it switches
patrick2664
Thanks. I finally found the problem. It was the tilt limit switch. There are two blue wires that come from the tilt limit switch. I traced these and found them behind the engine control module. I spliced them together and bypassed the switch. Works fine.
