Swap 1990's GM 3.0 for my 1970's 3.0?
jeffconnell12
Hi all - i have a bad motor in my 74 starcraft - it is the GM 140hp with a cracked block.
Prices are crazy for short blocks - but I just found a local 1998 3.0l complete/running motor. I've read about different flywheels and the couplers but I am confused - is there any reason I cannot just swap in this entire new setup without swapping components?
Will the original outdrive fit into the new coupler?
thanks for any help!!
Ayuh,...... Sorta,..... Yer gonna find the rear motor mount spacing is different,......
'n I don't know whether a '84 or newer inner transom plate swap will fix it,.....
Also, the drive input shaft on yer drive is 'bout an inch shorter,....
jeffconnell12
Thanks Bondo - so how would I pair my 74 flywheel, coupler and housing to the new motor.. I have access to a good machine shop.. wondering what the most economical way to do this..
Rick Stephens
I believe you will need to swap the inner transom plate and purchase the longer drive shaft.
Ayuh,.... I Think, you'll need to use the old flywheel cover, 'n get the sierra conversion coupler, that looks like yer old coupler, but bolts onto the new crankshaft bolt pattern,.....
1991 was the first year for new stuff - new block, new crank, new flywheel housing, and the A1G2
are you getting a new bob tail or new long tail?
jeffconnell12
Hi Scott - the new "used" engine (from 1998) is a complete running engine from front mounting plate to the coupler and housing.
I guess my options are:
1. find a replacement shortblock for my existing (cracked motor) and rebuild everything. Short block is approx $1000 canadian plus hone and machine then all other misc parts (aprox another $800).. if it matters i already have the entire motor disassembled.
2. purchase a newer 3.0L and attempt to do the conversion to make it work with my existing outdrive.. or purchase a gen 2 outdrive to match it. If i know its as simple as buying a newer motor then putting on the matching transom plate and driveshaft i'd go for it.. but it looks like the exhaust is different and who knows about fitment issues?
fishrdan
Option #3 - Find a rotter hull with good engine and drive, then swap everthing over, crank pulley to prop.
Scott06
you can use the 1998 motor with your old drive, you just need to use a different flywheel (purchased from GM industrial motors) and all your old flywheel housing, etc.
