Jeanninect
- Jun 20, 2015
- 4
Hello - I bought a 1990 Four Winns Freedom 150 with a Johnson 60hp, and just found out the 60 is junk (poor compression). I was able to find a 1993 Johnson 115hp to swap. I noticed the controls looks the like the same connections, but I'm wondering about the ignition motor cable assembly. I checked the model numbers on each engine's assembly and they are different, but the wires (color) and connector are identical. What the chances I can just plug the 115 ignition connector in to the current 60 connector and go? I don't want to short anything out. Thank you
