Re: Swap 20" shaft to a 25" shaft merc 175 hp lower unit
Will the boat perform properly if the gearcase is five inches higher on the transom?
If the motor has a removeable 5" spacer, and you change the studs to the shorter ones, and remove the water tube and shift shaft extensions on the midsection, you can swap the gearcases.
If no removeable spacer, you will need to install the 25" driveshaft, into the 20" gearcase.
