Swap a complete 1988 OMC 4.3 out and put a complete 5.7 Mercruiser I/0 complete with wiring harness in??
MFIC1960
1988 OMC 4.3 remove and replace with a 1991 5.7 mercruiser
Will there be any issues with transom cut out or anything else.
Thank you
nola mike
Same width, you'll need some extra room up front. Motor mount locations are different. Cut out is the same. You'll need a *complete* engine package, controls, wiring, exhaust, etc.
make sure there is 4" extra up front.
motor mounts will be 4" forward
cut out is similar, most you will need to do is a bit of clearance for the tiller arm.
as Mike stated, pulleys to prop, with controls and wiring
when you pull the engine out of your 1988 boat, check the stringers and transom for rot. do a few test drills
MFIC1960
Yes Sir ! I have the complete wiring, throttle/ steering and all wires down to the fuse and horn. Lol🤪
I appreciate your input. My local boat shop was telling me it’s not the same cutout on the transom.
And all stringer's and transom are solid. It actually a 1988 Playcraft 24’ hard top pontoon. So plenty of room 😄
Make sure the center pod is firmly attached
nola mike
V8 seems a bit of overkill in a toon, no?
MFIC1960
It’s all in nice condition, even the original seats. I had a 22’ Wellcraft. I had a semi built 5.7 built probably 340 to 390 HP.
Be for the motor when in we a nasty snow storm and about 25 trees down including
A monster that took out that boat.
achris
More fish than mountain goat
.... My local boat shop was telling me it’s not the same cutout on the transom....
That's an OMC Cobra, and if the cutout isn't the same, it's VERY close. All you might need to do is drill a coupe of 11mm holes at the top of the cutout.
achris
It’s already 30 MPH, after we make and install stakes and motor it should be a 45 mph minimum!!
Just a fun toy, pretty much a sleeper.
I think you're being a bit optimistic. If it's making 26knots with the V6, I think you'll only make about 5 or 6 knots more with a V8. Power vs speed increase is NOT linear, it follows the rule of squares. ie, doubling the power does not double the speed, it'll only increase it by about 15% to 20%.
Chris......
MFIC1960
Chris......
Okay, will sends pics later….
MFIC1960
Just found this?? Maybe the opening is not the same???
you will not need the AQ to SX conversion.
you simply need to unbolt the OMC, bolt in the mercruiser.
