Re: Swap Mercruiser 5.7L with a 355 - Can this be done?
kpkrol,<br />Welcome to the iboats forums.........<br /><br />Everything stated by the fella's Is a Fact.........<br /><br />But,<br />All these Can be gotten Around..........<br />By Mixing,+ Matching various Chevy parts, your combo
Can work.........<br /><br />For All intents,+ purposes, You're swapping a 5.7l Late model, for a 5.7l Early model(I just don't know Much Older Model)....<br /><br />The crankshafts have Either the 3 1/2"(early,2pc.seal) or 3"(late,1pc. seal) bolt patterns on the Flywheel end.....<br />The Flywheels are Either 153 teeth, or 168 teeth.....<br />Which means there's 2 Starters.......<br />Straight bolt pattern(153t), or the Staggered bolt pattern(168t).........<br /><br />Depending on Which Plant, Mercruiser was buying engines from, at the time yours was bought from Chevy,<br />You'll need a Flywheel with a 3 1/2" bolt pattern, <br />That Matches your Starter,<br />That Has the Clutch Bolt Pattern that Matches your Merc. Engine Coupler.........<br /><br />
btw: The crankshaft is moving an inch or two which is the reason for the replacement.
This is a Slight Exaggeration of Maybe .900, to 1.800 Thousandths...........<br />Right....??
