Swap prop in the water?
phillyg
Anyone ever successfully swap out their prop while still in the water? Trying not to have to have the boat hauled. I have a Bravo II outdrive and it can be raised in "trailer" mode which raises it fairly high, but the prop is still under water. I know how to change a prop ashore and I think if I properly grease the splines the water will be displaced when I install it. Thoughts?
Randy J
Re: Swap prop in the water?
get six of everything gonna loose about 5 of the six ,lolo dunno never tried that in the water repair old man murphey hangs around me all the time
craze1cars
Yes. Harmless and easy to do, even underwater. You won't hurt a thing unless you drop something and it sinks forever....
I guess in my mind, shallow water is suggested. I'm not as worried as much about dropping cotter pin/nuts/wrench, but accidentally dropping a prop in 30 ft of water would be a bit of a bummer, eh?
guy74
I change them all the time in the water, but mine lifts up above the water. Just as stated above, do it in shalow water, and have extra peices in case you drop something. One word of caution, make sure you don't pull the thrust washer off with the prop and let if fall into the water, and don't ask how I know that sucks :facepalm:
robert graham
Could you get the boat over towards the bank, shore, sand bar, shallow area?...would be a lot easier if you can get out and do this standing up, even better if you drop something!
lonemust
If you can trim it up all the way (with engine off ofcourse), it can be done real easily.. I just did it today myself.. What I did was to actually sit in the curve of the outdrive and reached down and took the one off and put the other on.. when removing the nut and washer just use both hands. one to turn the nut and the other to hold the washer.. took me all abiut 5min.
Leardriver
Done it plenty of times.
As Robert suggests, get the rear over to shallow water. Flip up the speedo sender so it won't break off. I use a knee board as a floating table for the bolts and hardware.
Of course, disaster is possible, but that just adds to the fun!
saintlee
tried 3 different props changing all in the water
i tied up to a piling to steady the boat
as everyone says - take your time to avoid dropping anything
NW Redneck
Just get a stringer drive. Makes prop changes on the water a breeze! :p ;) :D
phillyg
Thank you all. I am going to replace the prop at my pier at low tide so I can stand on the bottom whilst doing it.
boat1010
Have done it many times.. Not a problem.
I have done it many times, and I have had to go diving in with mask and snorkel a few times for parts.
a few key suggestions:
have extra hardware available (its really hard to find stuff in the silt)
if not in shallow water, tie a small line to a prop blade and on to your wrist
same goes for tools
make sure your buddies dont think its funny to give you a hand...or shove
Done it on Stringers and Alphas. the DP drive I currently have is a bit harder as the swim platform extends well beyond the drive.
Cap’n Ray
Did a prop swap recently on the old Bayliner with a pre-Alpha drive. Did the work in a slip at the marina (no shore power in the area) so was able to stand in the water and use the walkway as a tool and parts table. Just keep two hands on everything, take your time and you'll be fine.
natedog337
Just did the same and i concur, keep two hands on everything
captkevin
have done it a few times. If you have extra bodies on board have them go to the bow of the boat - will force the back of boat up - having them in the back of the boat only causes it to be lower & make changing harder. Don't ask me how I figured it out.
250Gimp
Did mine this past weekend, no problem!
As mentioned, two hands on each part!
Watch out for the thrust washer in case it is stuck to the prop a bit and falls off as you pull it off the shaft!
Cheers
Fishing Dude too
May I sugest try doing it at the ramp when it is not busy, I use a private ramp on Lake Erie so never busy. Have done reprop on several boats dragging it backwards into the ramp till almost bottomed out wit LU up.
cribber
You might want to invest in a marine magnet too. Won't help retreive the brass stuff from the bottom but does help get your prop wrench and other steel tools back if they hit the drink.
phillyg
This is a very late follow-up to my original post. I ended up having to have the boat hauled ashore for a totally other reason (but that's another long story I won't bore you with). I tried to install the prop myself while it was ashore. The hub was not perfectly aligned and prevented the prop from seating on the thrust washer by about 1/4". I've changed these props a couple of times and had never run into that problem before. Had I gone with my original plan to change the prop underwater as most of you agreed with, I probably would not have noticed it still needed to go that 1/4". The boat shop mechanic got it on somehow, but I was not there to watch what size hammer he used LOL. So, long story short is I'm glad it had to be hauled for that other reason.
