Re: Swaping lower units 130HP Johnson
That 130 uses a v6 gear case and prop shaft, as far as i can tell the only difference is the driveshaft and shiftshaft are slightly longer on the 130, the water intake holes on the 130 is more like one big hole, as opposed to a row of four on the v6, and the v6 case has speedometer hole in leading edge 130 does not. Both use same impeller, housing ect. I have run the same 24 raker on both boats (1150 lb each) and either motor will turn close to 6000 but the v6 is 10 mph faster with the same prop, so maybe there is a difference in gear ratio, but it could be due to the jack plate and hull differences too. I still say "take your's apart and see whats wrong with it rather than take a chance on getting a good one on ebay, or one that wont fit". I am usually not this adament but I just went through all this on my own boats, and I also went to some online parts sellers and checked parts numbers to find both supposedly use same driveshaft, but the tape measure don't lie, I am not sure about some of these retailers. As best as I can remember it is only about 8 bolts to remove that L/U, hint be sure and get the one furthest back on the shift shaft linkage or it will be 9. Then you can measure for yourself then send some questions to ebay sellers and get them to measure their's like I did. One inch difference any way you measure it.
