Hi guys
Strange one here... Aluminium 19ft cabin boat, 140 tohatsu 2 st - all speeds measured are gps
After smashing the original tohatsu prop and only ever getting to 5200-5300rpm WOT I decided to take a look at the variables, do some testing and get all my figures straight before getting a stainless 4 blader (almost all out boat use is ocean in up to 10ft swells).
Firstly I ordered a second hand prop made by yammy in the same pitch as the tohatsu 13 1/4 x 17. While I was waiting for this to turn up I took a much closer look at engine height. Measuring gave me the ventilation plate sitting around 2 inches below the hull, which would explain the limited WOT results. ( I dropped it down 2 holes when I got it because of ventilation, But more like my newness to boating). So I raised the motor back up so the ventilation plate is almost level with the bottom.
New prop arrived, paint sanded off as it looked pretty rough, fitted it, out on the water for some testing. Holy hell it has some holeshot, it jumps out of the water. But now the problem.... I cannot get to WOT ....at half throttle and neutral trim I'm pushing 5900rpm and around 28knots. The old prop with lower motor position gave 32 knots at 5200-5300 rpm so I don't know what the hell is going on. I thought same pitch should give same results but there must be something drastically different between the props but I don't know what. I doubt its the raising of the engine 2 holes..
Other than the stamp on the prop is there and easy way of checking actual size. This isn't helping my facts to establish the pitch I need for a 4 blader!
Any thoughts what could be going on here?
Appreciate any help and opinions
Steve (Australia)
Steve (Australia)
