Swapping Engines - outdrive question
jmcknight
I have a 97 good 3.0LX mercruiser with a 1.94R outdrive. I have a bad 99 3.0 mercruiser with a 2.00R outdrive.
I put the 97 engine with the 2.00R outdrive. Is that OK? or do i need to leave that 99LX motor with the 1.94R outdrive?
kind of confusing ....
Thanks for your help.
Bt Doctur
Re: Swapping Engines - outdrive question
that close it should not matter 1.98 or 2.00
jmcknight
well it is 1.94, but what are the risks i'm taking? could it cause damage, or just not work properly?
also, if i do change the outdrives, should i just need to change the outdrive or the transom also?
Ayuh,... Realistically, the 1.94:1, the 1.98:1, 'n the 2:1 are the Same ratio...
Direct swapability...
jmcknight
Awesome thanks for the input guys
