swapping top half - tower of power
octaneforce
i have a mercury 90 tower of power with a blown cylinder, but the lower end is still perfect. i found a mercury 115 tower of power with a bad lower end, but a good running top half. how hard will it be to swap the top halves of these motors? i looked at my 90 quick and saw two bolts under the front of the cowl. anything i should be aware of while doing this? i noticed that the gear shift mechanism might be a little tricky when doing the swap.
Droll
Re: swapping top half - tower of power
What years are we talking about here ??, if we're talking about swapping the complete power-head... ALL inline 6 engines produced between 1973 and 1988 can be used.
There are some differences over the year but the main parts will interchange.
Arne Kjetil
octaneforce
both motors are mid 80's. i am really not sure of the exact years. i want to swap in the entire top half of the outboard. i am taking the 115 top half and putting it onto my 90.
daveswaves
Ensign
As Arne said, they should be a direct switch, if the 115 runs well why not put the lower end from your 90 on the 115...a lot less work.
octaneforce
sorry, thats what i meant. i just want to use the lower end of my 90. but how do i go about removing the lower end from the 90? wouldnt that be the same as swapping the top halves?
daveswaves
Ensign
Assuming the mid section is ok on the 115 you will be better off just removing the lower unit from the 90 and swapping it to the 115. It would be a good idea to change the water pump while you have the lower unit off. I think what may be confusing you is there are 3 sections to the motor, not 2. If you clamped the motor to the boat and removed the power head and the lower unit, the mid section would be what is left on the boat.
Mi duckdown
You really need to know the exact year of both motors. Got serial numbers?
octaneforce
ohh okay that makes sense. thanks for clearing that up. what do i have to do to remove the lower end? ill have to take a look at my motor tomorow morning.
Mi duckdown
The gear ratio can be different on the lowerends that is why you need to have the serial numbers of both motors to cross reference.
daveswaves
Ensign
True, it is possible, especially if one is early 70,s. It sounds like they are both mid 80,s though and if the lower units look the same physically from the outside, newer swept back design, then they are likely both 2:1. Pictures would help, of both engines.
Chris1956
Sounds like you need a service manual, since you should rebuild the waterpump whne you have the gearcase off. The Gearcase is removed by removing 5 nylon lock nuts and a bolt. Of course the bolt is hidden under the zinc anode. The zinc anode is removed using a thin wall 3/8" drive socket or an allen wrench.
to reinstall the gearcase, the driveshaft splines must be greased and mated to the crankshaft splines. Ditto for the shiftshaft splines.
daveswaves
Ensign
There is no reason that the two lower units will not swap over.
octaneforce
okay thanks alot! i will let you guys know if i run into anything during the swap
