Hello, I'm looking to get some feed back ideas/comments/suggestions on my near future plans for my 1977 Marquis with a Mercruiser 888. Currently having some trolling issues with this motor and with the help of 5 gallon buckets got the idle speed down a little but dont want this to be a permanent solution so I have decided to go with a kicker. The problem is the swim platform takes up alot of space so this will be removed and maybe later a smaller custom one opposite side of the kicker.
After doing some research and correct me if I'm wrong, This should be done to each screw hole:
1) Drill the hole a size or two bigger to remove any worn/rotten wood
2) sand the area surrounding the hole
3) Fill with Marine Tex Epoxy (Any suggestions on another product you may find higher quality for the job would be appreciated)
4) After drying, sand accordingly
5) Mount kicker bracket as close to stern while allowing clearance of both to function properly
Here are a few pictures of the boat:
Backside of boat-
Swim platform support bracket-
Inside of boat-
If any more pictures are needed please let me know and ill get them. What I'm looking for is any feed back as to what else I should do or what I would be doing wrong before I go drilling into my boat lol Thanks in advance for your help
Backside of boat-
Inside of boat-
