switch polarity
overthere
If a boat has been rewired with all the switches on the negative side is this bad will it have to be redone on the positive side?
Silvertip
Re: switch polarity
Switches should never be installed in the negative side of a circuit. The one exception is electronic engine controls where sensors may grounding types. Are the fuses or breakers in the ground side as well? If so, that boat is a recipe for disaster.
