completetech
- Jul 7, 2012
- 22
I have a couple of questions about switches all wrapped into one post.
Sorry for the super long post. I am new and thought it best to put as much detail as possible in the post to show what I have and what I am hoping to accomplish with my new(er) boat.
The details (of the boat):
Procraft Maiden Craft 1700 (I think 1978).
Johnson 150HP Outboard.
OMC Remote Control.
Gauges(currently onboard):
Tilt
SurTemp
Speed
Tach
Fuel
Battery gauge(front Deck).
Wiring:
Motor to remote -
red
purple with white stripe
black
black with yellow stripe
yellow with red stripe
purple
brown (goes to absolutely nothing).
Gray (cant seem to find where this actually ends, but its going somewhere).
Remote Control out to main switch area:
red with white stripe
blue with white stripe
green with white stripe.
Switches:
Drivers area Switches:
Lights – up/middle/down – labeled as up equals both. (4 terminals)
ACC – up/down – (2 terminals).
Master – up/middle/down. (6 terminals).
Aerator – up/down. - (2 terminals).
Bilge – NO SWITCH present.
LED Light (not sure. Maybe to indicate power? 2 wire but one is broke off.
Horn – no switch present.
Front Deck Switches:
Lights(broken switch) – up = nav| down = stern. (4 terminals).
Aerator(broken switch) – up=aerator| down=bilge (3 terminals).
Tilt – up=up | down=down (3 terminals).
Batt Check(broken) – up=batt 1 | down=batt 2 (6 terminals).
So there are the details above. Now I will get into the question(s).
The short is I would like to have everything working.
I currently have a huge mess of wires / wire harnesses. I am looking to clean it up some. I do low voltage wiring for a living and love labeling everything and having it organized to make things easier to troubleshot if ever a problem. The big issue I have is that there is a mess (based on the attached pictures https://picasaweb.google.com/lh/photo/Wuf7S_AA1lg7pb8m4bgaLY2EPq7RJzIADC7KsembYek?feat=directlink). But yet the wires / harness seems to go all throughout the entire boat. i.e. from the main gauge set near drivers seat, it goes up to the front of the boat to the gauges etc.
So I am looking to figure out the best way to wire up the above gauges / switches as I am not that familiar with 12volt / boats.
I can obviously figure out which wires to use my self (i.e. brown and brown with black stipe to switch 1, etc). But I am kind of lost as to where to start.
Issues:
Now to the front of the boat. The Deck. I have a total of 3 batteries. Two batteries, on what I'll call the “other side” and one behind drivers seat. The batter behind drivers seat goes to the motor to start. The other two on “the other side” appears to go to the front of the boat to the funny connector to the trolling motor plug. However I am pretty positive the two batteries I'll call ACC batteries that run to the front are not hooked up properly (look at the picture https://picasaweb.google.com/lh/photo/3jcuVHiihZeytpP7c8QVMI2EPq7RJzIADC7KsembYek?feat=directlink) as only one negative wire is all that is hooked up at the deck, near the battery check gauge, but as you can see the gauge isn't hooked up either, which I really feel like it should be.
I also have some super old tube style fuse holder. That reminds me almost of something you'd use as a temporary thing to test items. Basically I have no fuse block or grounding block. Looking for some suggestions.
Wish List:
Everything working one the boat. All current switches / gauges.
Add maybe 1 or 2 Cigarette lighter charging ports for phones etc.
Add a battery gauge that I can check all three batteries from drivers seat.
Add maybe a stereo.
New fuse block (looking for suggestions as I currently don't really have one)
New Grounding block (also looking for suggestions.
Have everything wired the way it is supposed to be (i.e. ACC items going to whatever battery it is supposed to be going to, whether the ACC batteries going to trolling motor plug or wherever).
Ability to charge ACC batteries while motor running and also charge / condition batteries when I get home (saw something, somewhere along the line of a device that is wired up and you plug an extension cord into it and it does this for you).
To get both Live well's working as the only switch or anything on the boat for it is on the front deck. But I have one on the front deck and one in the rear of the boat. But there is no wiring that I see running there.
And of course wire me up a fish finder. But once I figure out some of the basics should be easy enough.
So that I think covers it all. I hope.
Thanks for reading all of this.
Nathan
OMC Remote Control.
Tilt
SurTemp
Speed
Tach
Fuel
Wiring:
Motor to remote -
red
black
purple
Switches:
Issues:
Wish List:
Add maybe a stereo.
Nathan
