switching dipstick tube
NHGuy
I'm switching over the carb, ignition, water pump, etc to my new engine and I wonder if there's a good way to get the dipstick tube into the new block. I had a bit of an ordeal removing it from the old engine. It was a snug fit.
Should I freeze it to make it shrink? Lubricate?
GA_Boater
Is the tube straight? A length of small diameter pipe over the tube and tap it in.
FunInDuhSun
Ive used an appropriate-sized deep socket pushed down to the wide spot and tapped it down and in.
I have a ratty old vice grip pliers that I drilled a hole thru where the jaws come together. I clamp it on the tube just above the flange, then smack the pliers with a hammer driving in the tube. I used it on a few SBC's so far.
NHGuy
The tube is very long and has two 90 degree bends before it gets to the flange, so Scott's way is the only one I can see using.
So the tube (looks like stainless) is strong enough to hammer into the block? That's good, cause I could not see any way to arrange a press fitting.
flipbro
Master Chief Petty Officer
NH is it possible to freeze the dipstick tube and heat the opening with a heat gun? That should contract and expand things enough..
