Switching to a charging system...
usernamekane
Hey ya'll!
I gotta 35753C, a 1977 35hp...it has a manual start igniton, but also a starter( in addition to original pull start rope), and the boat now has lights and a fish finder...so, i want to install the charging ignition I have laying around. I have the wiring harness for it, the rectifier, the mounting bracket and terminal block, even the neutral switch. Can I just take off the flywheel, and do the swap? It looks like I just need to tap in with the red wire going over to the solenoid(the one thats also hooked directly up to bat +), plug in the 4 prong plug, plug in the neutral switch, and I'm good(after the physical bracket mounting). Both flywheels say CD ignition, and appear to be identical. Am I missing something? Will the timing be the same or...? Thanks for the help!
Goto http://12.2.215.22/pub/default.asp?SessionId=a0b7b454d0a04e58a28db1e3f3e3d0cd&Lang=EN&brands=EJ
I'd be replacing #8 and all the attached stuff with #26 etc. I also have, and would be installing, the stuff associated with #7(rectifier stuff) and #4(junction from stator to rectifier). Thanks again.
