I just finished installing new OEM bellows in an Volvo SX tonight. I never removed the bonnet, and yes that does make it easier like Bruce said.. I take and bungee the bonnet up as high as possible. I pulled the shift cable away a little also. I left the water supply alone, I felt like there was now enough room to install. The bellows I have were the newer hard plastic in the center ones. They are a little stiffer than the solid rubber ones with a spring inside. After cleaning, I used dish soap and a little water to lube up the boat side . I did the u-joint bellows first . The boat side popped right on, and the rubber ring on the billows seated very well. Before you remove the old one, take a look or mark how far the old bellows are back on the boat tube. The rib on the bellows will seat on the boat tube when you are back far enough.The hardest part for me, is always those dang ground clips that fit under the clamps. I put the clamp on before releasing the bonnet. Now you have to collapse the drive side of the bellows to pull it inside the drive. There is no easy way here, and I used a lot words you don't use in Christmas carols. My exhaust bellows were nothing more than a short snout with an open end. As before, the hard part is getting the clip under the exhaust clamp . Took about 2 hours, and the alignment was perfect, also the gimbal bearing felt like new so nothing needed there. You will need a long 1/4" extension with a 5/16" socket to reach the clamps. Good luck Dave-R
