sx drive doesn't lock in
Robert Malta
Hello from Malta,
We are installing new D3-130 Diesel engines with SX drives.
All went well till we tried to lift the SX drives and put them into the brackets.
We got in - but for 50 mm - the last part to fix the bolts.
We tried to rotate the propellor in forward and in reverse - but no luck
Anybody with bright ideas and experience for this problem?
Please HELP......
Kind regards
Robert
PS our project can be viewed, including where we got stuck at the Google /Picasa site following this link:
https://picasaweb.google.com/lh/sre...1sRgCNmj0e_hzaDqTQ&invite=CNDk-4UG&feat=email
The last images in the album show the problem in detail (more or less)
Don S
Re: sx drive doesn't lock in
Did you make sure the engine alignment was ok?
It may be the new orings on the ujoint shaft. Put some oil on them. Sometimes you have to bump the drive a bit to get the orings past the gimbal bearing the first time.
Robert Malta
Thanks Don, many thanks for your time, yes we did, we bought a special alignment tool from Volvo, we tried it before setting the engines and then before we put the drive in place. See image 149 of 152 in the picasa album. The alignment is 100% OK.
EngineChangeOldShatterhand
Don S
Just to prove a point, carefully remove the orings shown in the picture. Then see if the drive goes all the way on easily. If it does, put the orings back on and put some oil on them. Then give it a kick, it's go.
Robert Malta
:) Good morning and thanks again....we will try it and keep you informed.......wish you and your dearest a nice day
